This command disables the specified IS-IS router process on the current virtual router.
| area_name | Specifies the name of the IS-IS router process to be disabled. |
Disabled.
IS-IS PDUs are no longer sent or processed on this IS-IS router process. The LSP and neighbor databases are purged. IS-IS routes are purged from the routing table. This command should only be used during planned network outages. This command has no effect on router processes that are already disabled.
The following command disables the IS-IS process named areax:
disable isis area areax
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
